tricks for kan (2nd octave)
divino_marchese
There are several posts in this forum, also in the "old edition", but I'd like to take in mind some player tricks in order to obtain a correct kan (second octave). I'm able to play almost all the notes (some times there is a noticeable white noise and I'm trying to control it) but I've some problems with the last note of kan - ha, if I'm not wrong - namely the third D of a 1.8 shakuhachi. What is the role of the thumb (5th hole) in playing kan. Half covering the 5th hole with the thumb make me able to play easily, smooth and "rounded" notes for ro and tsu ...
Thanks for replay.
PS I'm a beginner player!
LowBlow
In kan the thumb hole is always covered. The third octave is called dai kan. When playing dai kan ro (go no ha) open the thumb hole completely and lower your chin (play in meri position).
You can half cover the thump hole. This gives a different timbre depends a bit on your school.
Pitch and sound will come over time. 'The key is practice.
No tricks. Practice, practice, practice.
divino_marchese
"LowBlow""LowBlow"
Thank you, I'm confused about some chart ...
LowBlow
"divino_marchese""divino_marchese"
Yes, there are different charts between the schools. You have alternative fingering for some notes within the schools as well. Depends on the piece you play.
The basic notes are the same though.
To make it worse in dai kan the fingering can depend on your flute a lot.
