Urushi Adventures
Urushi Adventures
I just got some urushi from a woodwind instrument maker.
That urushi was lying around his stuff for many years unused, so he let me take some.
I filled few metal tubes and tried to copy the labels of the originals and also got few smaller tubes with stuff he said is urushi sabstitude but since i know cashew urushi already i know the tube looks diffrent.
I started working with what i think is roiro urushi which is very black and thick, trying to make some loose flute joint snug again,
its preety dry after 2 days in a humid box but got some stuff that looks like dust particles in it and also few wrinkles although i tried to paint in the thinnest layer i could.
This lacquer is beautiful! i also think im lucky to be not allergic to it since i touched it few times, washed my hands and nothing happen.
I got so many questions but no one to ask them and also couldnt find the answer anywhere on the net.
what is written on the labels?(-see pictures)
how can i filter the urushi other then the traditional paper method?
should i filter it at all?
should i always use shuai urushi (that brown translucent one) as a primer before the others?
How can i polish it/sand it/etc?
how long does it take to dry before you can sand it/ put the joint together?
and also specifically how can you know if you got a fit when you work on a flute joint? because the flute swells moisture and the joint is tighter then it is normally.
Any info would be appreciated.
Thanks!!
Thanks!!
update: i think the roiro is the glossy type, it dries glossy but with tiny particles,
the second one is Shuai urushi, dries dark brown. and the third opened tube i have no idea.
i did 2 lyers of roiro urushi, first one had to be sanded because it was buckled and unclean, second one was thinned with a bit of turpentine, some of it got glossy finish and some of it matte finish...its weird
any tips about polishing urushi?
oh and here is a link to a nice Urushi Glassory:
http://www.hakuminurushi.com/urushi/glossary.html
